Hi everyone,
I am not certain this is the place for this question but from what i gather it is likely to be where I can get the best help.
I have a dynamic block where i have entered multiple fields (paper size, date, file name, etc.) to include in my layouts.
All the fields update accordingly with "regen" or at moment of plotting to paper or pdf, except for the paper size field.
The only way it updates is if the mtext box the field is in, is not inside of a block.
Why does that particular field not update when inside a block, whilest others do ?
I have attached a file with said block and mtext, as well as different lyouts to test.
( I am using Autocad 2024 on a PC)
Thank you in advance.
