AutoCAD Forum
Panning?
9 REPLIES 9
Message 1 of 10
1853 Views, 9 Replies
Panning?
Sometimes while panning it locks on and takes control. Is there a way to turn this "feature" off?
Tags (1)
9 REPLIES 9
Message 2 of 10
rkmcswain
What locks on? The pan command? You can't exit PAN?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 10
in reply to: rkmcswain
Thanks RK,
When I left click and hold it I can pan. Sometimes when I do that and let go of the click, the hand is still there and in pan mode and i move the mouse around and it still pans without holding the click. Hope this makes sense
Message 4 of 10
What locks on? The pan command? Correct
You can't exit PAN? Only if I hit escape
I cannout recreate this action it only happens once in a while.
I have looked at the History / F2 button and it dosent show as a command. I have a feeling this is related to 3d pan.
Message 5 of 10
Emmsleys
Hi @Anonymous,
Welcome to the Autodesk Community Answer Day. Smiley Happy
A fix that was implemented in 2014 allowed the zoom and pan function to work but had the side effect of pan sometimes locking/getting stuck (usually document and machine dependent). Our development team is currently investigating the problem
Workaround for now is to hit ESC to get out of the pan command.
Sarah Emmsley
Technical Support Specialist
Message 6 of 10
rkmcswain
I know this sounds very basic, but is it possible that the left mouse button is sticking in the down position?
Message 7 of 10
Goody1977
in reply to: Emmsleys
Very annoying, I have to save to get it to exit the command. Escape does not work.
plan on using the space bar next time, but would like to see this fixed as it is a huge time killer.
Message 8 of 10
RobDraw
in reply to: Goody1977
Have you considered that there might be something you can do to fix it?
You should ask in a new thread. Make sure to state your version and hardware specs.
In the mean time, you can try a different mouse to see if the problem still exists.
Rob
Message 9 of 10
the problem still exists! your developers did not solve it in 2021 either
Message 10 of 10
RobDraw
If it exists, tell us how to recreate it. If it cannot be recreated, how can it be fixed?
Rob
AutoCAD Inside the Factory
