AutoCAD Forum
P-Line Global Width
1 REPLY 1
559 Views, 1 Reply
P-Line Global Width
Hello Folks,
I'm drawing a lot of p-line-type entities that need the same Global Width.
I've changed the PLINEWID variable to .25". Now, invoking the PL command results in poly lines with a visible width of .25". This is the desired effect.
Invoking the RECTANG command, however, produces a pline element with a global width of zero (0). This can be modified after the element is drawn.
My guess is there are other pline-type elements - much like RECTANG - that do not apply the PLINEWID variable when created.
Are there a variables I can change to apply a default Global Width to all p-line-type entities?
I'm trying to work fast. Help in determining if I'm wasting my time trying to locate and change a bunch of variables as opposed to just modifying the Global Width to all pline-type entities as I finish the drawing would be good to have.
Thank you,
Mel
1 REPLY 1
Kent1Cooper
That is correct -- REVCLOUD, POLYGON, and BOUNDARY & SKETCH in their Polyline options.
RECTANG at least has a Width option that "sticks" within the same editing session of the same drawing.  But I don't know of a way to make it generic, other than your idea to change them all when you're done drawing.
Kent Cooper, AIA
Forma Design Contest
AutoCAD Beta
