Hello Folks,
I'm drawing a lot of p-line-type entities that need the same Global Width.
I've changed the PLINEWID variable to .25". Now, invoking the PL command results in poly lines with a visible width of .25". This is the desired effect.
Invoking the RECTANG command, however, produces a pline element with a global width of zero (0). This can be modified after the element is drawn.
My guess is there are other pline-type elements - much like RECTANG - that do not apply the PLINEWID variable when created.
Are there a variables I can change to apply a default Global Width to all p-line-type entities?
I'm trying to work fast. Help in determining if I'm wasting my time trying to locate and change a bunch of variables as opposed to just modifying the Global Width to all pline-type entities as I finish the drawing would be good to have.
Thank you,
Mel
