Announcements
Order attributes blocks in block.dwg instead of drawing with block
sander.van.pelt
sander.van.pelt
Hello all,
We use another application within AutoCad to draw HVAC installations. Now we place several blocks which all contain attribute definitions.
However, the attributes are not in a logical/correct order.
Now I can change that order in every drawing with BATTMAN, but if I add the same block in another drawing, then everything is wrong again.
If I open the block itself, the dwg, then I cannot put these attributes in the right order because in this drawing it is not a block but an ordinary drawing with some lines, solids, logo (removed in attachment) and 38 attribute definitions.
How could I ensure that this block is inserted in such a way that the order of the attributes is correct/are in a much more logical order?
Now you see the properties of the block in the image. For example, here you can see that the "MOD_CODE_" attributes begin with "MOD-DATE_F". But the entire sequence "MOD_DATE_F" through "MOD_CODE_A" should start with "MOD_CODE_A" and end with "MOD_DATE_F". Completely the other way around. These attributes must also be at the very bottom of the list, because they are less important because they are not filled in everywhere.
tramber
I would :
Insert the block somewhere. Explod it.
Then i would use the BLOCK command itself and select the attributes in the right order, one by one and then the rest of the objects (taking all, doesn't matter if it includes the already selected [one by one] attributes, by the way).
Then i would WBLOC the block I just would have created to put it where you want, as a dwg, i.e. your wish.
Should work 😉
NB : in fact, the only use of WBLOC would be possible, not necessary to use BLOCK.
cadffm
Or open the modelspace by BEDIT and use BATTORDER
Sebastian
sander.van.pelt
Thank you Tramber!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
