Define a point of anchor in a block for connection with other shapes
I'd like to know if is possible to define a custom object that can be put in connection with other blocks exposing a certain point on its border for the anchor. Sorry if I'm not using a specific autocad language in my description. If possible can I know all the shapes/object that are connected with my block?
I'm a computer scientist not an Engineer. 🙂
Best Regard,
Marco
Replies (12)
Bob_Zurunkle
I have seen some ability with dimensions but not with leaders as in your example. Using the stretch command (crossing option) around your block and the end of the leader will move both simultaneously.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
dbroad
Multileaders can already be associated with block inserts as long as an object snap is used to specify the arrow position.  If you want to develop your own objects, look into programming with .NET.  To prototype the behavior with AutoLISP, you could explore object reactors, specifically the :vlr-modifed and :vlr-openedformodify events.
Architect, Registered NC, VA, SC, & GA.
RocksterB
Looks like something done by Lee Mac’s lisp.
dbroad
There was no lisp in my demonstration.
Thank you,
I've other questions 🙂
Can I define the points in which the block should be osnapped ?
Only arrows can be connected to the block?
Can I know somehow how much arrows are osnapped to my block ?
Best Regard,
Marco
dbroad
These are really questions that you should be able to investigate yourself.
  • Can I define the points in which the block should be osnapped ?
    • Certainly. This is as easy as adding points to the block definition. Do you not have AutoCAD to test with?
  • Only arrows can be connected to the block?
    • I don't understand the question. I used the leader command and used object snap. As I said before, if you want to implement custom behavior with other types of objects, you need to create the reactors yourselves.  This is a complicated process without using .NET.
  • Can I know somehow how much arrows are osnapped to my block ?
    • This is also a question that could be answered by (entget (car(entsel))) on the block.
((-1 . <entity name: 35ae76c0>)
  (0 . "INSERT")
  (5 . "2C4")
  (102 . "{ACAD_REACTORS")
  (330 . <entity name: 35ae62f0>)
  (330 . <entity name: 35ae6410>)
  (330 . <entity name: 35ae6530>)
  (330 . <entity name: 35ae6650>)
  (330 . <entity name: 35ae6770>)
  (330 . <entity name: 35ae5110>)
  (330 . <entity name: 35ae5230>)
  (102 . "}")
  (330 . <entity name: 4bd43700>)
  (100 . "AcDbEntity")
  (67 . 0)
  (410 . "Model")
  (8 . "0")
  (100 . "AcDbBlockReference")
  (2 . "test")
  (10 0.0 0.0 0.0)
  (41 . 1.0)
  (42 . 1.0)
  (43 . 1.0)
  (50 . 0.0)
  (70 . 0)
  (71 . 0)
  (44 . 0.0)
  (45 . 0.0)
  (210 0.0 0.0 1.0)
Simple test:  Compare the entity data list before and after snapping leaders to it.  Here is a screencast.
Ed__Jobe
Computer scientists usually use Microsoft Visio for what you want. This type of functionality is built in. It is used to create flow charts and computer aided software development.
Ed
How to post your code.
Ok,
very wonderful, but can I set a rule for whic my box should accept Leaders only at a certain point in its circumference?
Bye,
Marco
dbroad
I'm not sure that I understood the question but if using mleaders, then only if you could prefilter the point selection before issuing the mleader command.
I'd like to set a rule on my block: "the block can be connected only by 1 leader".
If a leader is attached to the block and I attemp to attach another leader must be impossible.
dbroad
You can't limit how the multileader command works.  You can undefine it and then add parent logic and use the built-in version as a subroutine. Someone can still access the built-in command by using the "." prefix though.
mikael_forsbergHTRNV
Hi Doug,
I'm resurrecting this forum post because I have the exact same question as Marco.
Although I can't figure out how you get the leader to associate with the block in your screencast?
Perhaps I misunderstood and you have to program it?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
