Hello! I imported that file from 3ds max to autocad. How to optimize it for cnc? The problem is that it has to many points.
There are no points (I see) on straight edges that can be deleted without losing quality. I also can't find curves like arcs with constant radius ... so: You know that in that case less points means less quality?
And what means too many? 10% too much or 10 times too much?
- alfred -
There appears to be a section with geometry in the Z direction. Is this an intentional part of the design?
CADnoob
there are a couple way to get this down see this article for a couple. probably the easiest would be something like FLATTEN, but that command always see to be a mixed bag for me.
EDIT: I just ran flatten and it significantly changes the lines... id try something else.
CADnoob
i got better results with this (note the script has some licensing/adds) http://forums.autodesk.com/t5/autocad-2010-2011-2012/how-to-globally-change-all-z-values-to-0/td-p/3...
CADnoob
