AutoCAD Forum
Optimize file for cnc.
6 REPLIES 6
449 Views, 6 Replies
Hello! I imported that file from 3ds max to autocad. How to optimize it for cnc? The problem is that it has to many points.
6 REPLIES 6
Alfred.NESWADBA
There are no points (I see) on straight edges that can be deleted without losing quality. I also can't find curves like arcs with constant radius ... so: You know that in that case less points means less quality?
And what means too many? 10% too much or 10 times too much?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
TheCADnoob
There appears to be a section with geometry in the Z direction. Is this an intentional part of the design?
CADnoob
in reply to: TheCADnoob
No that looks like error.
TheCADnoob
there are a couple way to get this down see this article for a couple. probably the easiest would be something like FLATTEN, but that command always see to be a mixed bag for me.
EDIT: I just ran flatten and it significantly changes the lines... id try something else.
CADnoob
TheCADnoob
i got better results with this (note the script has some licensing/adds) http://forums.autodesk.com/t5/autocad-2010-2011-2012/how-to-globally-change-all-z-values-to-0/td-p/3...
CADnoob
Patchy
Convert it to LWPOLYLINE and Flatten it, run a PLDIET.LSP by Kent Cooper
it will reduce the vertices.
AutoCAD Inside the Factory
