AutoCAD Forum
Objects get cut off when zooming in
5 REPLIES 5
GK_TC
1078 Views, 5 Replies
I'm having an issue where anytime I zoom in close to an object, it's like an invisible plane cuts it off before I can get close up to it, and it just disappears (see attached video for demo, or view here). For the life of me I can't figure out what's causing this to happen, but it's becoming excruciatingly frustrating.
I've tried turning off hardware acceleration and trying various GRAPHICSCONFIG settings, to no avail; any suggestions would be appreciated.
System Specs:
Windows 10 Pro 64 Bit
Intel i7-8700 6-core, 3.2GHz
16GB RAM
NVIDIA Quadro P400 2GB video card
5 REPLIES 5
Alfred.NESWADBA
in reply to: GK_TC
please
  • upload the dwg-file
  • start command _ABOUT and show us a screenshot from that dialog (we don't know the product and version you are using)
  • start command _GRAPHICSCONFIG so we see which graphic card and driver you have
-  alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
GK_TC
in reply to: Alfred.NESWADBA
No problem, here's the file I'm working on and the requested info screens.
Alfred.NESWADBA
in reply to: GK_TC
you screenshot shows that your AutoCAD 2019 is not up-to-date.
While I'm downloading your drawing and looking into it I recommend to install update "AutoCAD 2019.1.2"
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
in reply to: GK_TC
it's perspective mode, a display clip is needed as the camera (you have virtually) can't look behind your location.
You can play with system variable PERSPECTIVECLIP and change it from 5 to 1, run _REGEN ... better?
- alfred -
Alfred NESWADBA
GK_TC
That's exactly what I was looking for, thank you!
Forma Design Contest
AutoCAD Beta
