I'm having an issue where anytime I zoom in close to an object, it's like an invisible plane cuts it off before I can get close up to it, and it just disappears (see attached video for demo, or view here). For the life of me I can't figure out what's causing this to happen, but it's becoming excruciatingly frustrating.
I've tried turning off hardware acceleration and trying various GRAPHICSCONFIG settings, to no avail; any suggestions would be appreciated.
System Specs:
Windows 10 Pro 64 Bit
Intel i7-8700 6-core, 3.2GHz
16GB RAM
NVIDIA Quadro P400 2GB video card
Solved by Alfred.NESWADBA. Go to Solution.
please
- alfred -
No problem, here's the file I'm working on and the requested info screens.
you screenshot shows that your AutoCAD 2019 is not up-to-date.
While I'm downloading your drawing and looking into it I recommend to install update "AutoCAD 2019.1.2"
- alfred -
it's perspective mode, a display clip is needed as the camera (you have virtually) can't look behind your location.
You can play with system variable PERSPECTIVECLIP and change it from 5 to 1, run _REGEN ... better?
- alfred -
