just started using Autocad 2019. While in a dwg file, all the elements in the drawing suddenly became very bold. so bold ,or thick that they look like blobs , lines circles everything. can figure out why.
Solved by rkmcswain. Go to Solution.
Seems like the lineweight display is turned on. You said it's off, but do you mean it was just not checked in the drop down picture shown by Rk? Checking that doesn't turn it on. What it does is add the button to the bottom tool bar. You need to check it and then shut the button off it adds to the toolbar. Either that or type the command. You might have done that all but just checking as we have no idea how well you know autocad. We get many very novice questions here.
Can you post the dwg of the screenshot you posted so we can look and see?
Nick DiPietro
Cad Manager/Monkey
attached screen shot including command line and task bar
same file. but copied elements before the issue started . I had copied the elements to use multiple time in same drawing. as soon as i click on one line, they all change to bold. also,before they change, if i click on a line, it gets this "shadow around it.
