Object basepoints change everytime.
dogukan.hos
Message 1 of 8
dogukan.hos
I have a file that works I keep my templates. Every once in a while objects basepoints keep changing, to fix it I use "Flatten" then use block editor to fix their basepoints every single time and it gets frustrating. I have no idea why this keeps happening but I'd appreciate a permanent fix for this problem.
Replies (7)
Message 2 of 8
vinodkl
Hi @dogukan.hos
Try to "PURGE" and "AUDIT" the drawing to remove any errors in the drawing and see if that fixes the issue 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 8
imadHabash
I wonder also why it's happening !! can we know what it is the nature of those objects ( Blocks , Attributes , ... ) ?
if you copy those objects to a new empty drawing , any changes ?
Imad Habash
Message 4 of 8
dogukan.hos
Hello, thank you for your reply, I repeated what you said twice, was that supposed to fix my basepoints automatically or am I supposed to fix basepoints manually once more and the problem shouldn't occur again?
Message 5 of 8
dogukan.hos
Hi, I think this only happens with the blocks. Posted a screenshot. I'm also sending the DWG file.
Message 6 of 8
imadHabash
After i open your drawing :
  • your dimensions has a z axis value  !!
  • I fix the cyan circles basepoint .
  • The other blocks are fine when i use it .
Find below attached CAD dwg and see if it's help .
Imad Habash
Message 7 of 8
dogukan.hos
Thank you very much, they work fine now except one I forgot to point out, how can I do it myself? Also how can I disable Z axis entirely? I've never needed it once and I probably never will.
Message 8 of 8
Kent1Cooper
@dogukan.hos wrote:
.... how can I disable Z axis entirely? I've never needed it once and I probably never will.
Read about the >OSNAPZ System Variable<.
Kent Cooper, AIA
