AutoCAD Forum
No grips on hatches in Autocad 2018
34 REPLIES 34
Message 1 of 35
ruslanvremea
28676 Views, 34 Replies
Help me, please, to get grips of the hatches in Autocad 2018.
I already tried to disassociate many hatches in various way: exploded boundaries; changed settings in Properties and Hatch Editor, and even opened some older dwg files (2011 and 2013 version) which contains disassociated hatches but the results are the same – hatches don’t have any boundary grips, except the only one in the center.
Thanks a lot.
34 REPLIES 34
Message 21 of 35
I'm not sure that naming this here will be ethic, sorry.
Message 22 of 35
in reply to: ruslanvremea
Hello, i have the same issue with 2018, plz let me knw which extensions to be removed??
Message 23 of 35
May be alfred can be help me plz
Message 24 of 35
Alfred.NESWADBA
do you have a "SPDS Extension" installed (some additional options/functions for Russian standards)?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 25 of 35
Hi ruslan, thanku for your support, solved it. Wrking perfectly
Message 26 of 35
Hi alfred, wrks fine now. Yes u r correct. It was SPDf extension thankyou
Message 27 of 35
Hi, I got stuck with the same problem.
Witch extention you unistall and how?
Message 28 of 35
Hi there will be SPDS extension folder on installed location of cad. Delete the entire folder n try.
Solved my issue with this solution.
Message 29 of 35
What did you uninstall!!!!!???
Message 30 of 35
Alfred.NESWADBA
Look to post 24 in this thread.
- alfred -
Alfred NESWADBA
Message 31 of 35
in reply to: Alfred.NESWADBA
yessss it worked!!
Message 32 of 35
I uninstalled Autodesk SPDS 2018 Module (Russian CAD Standard) and works fine!
Message 33 of 35
I don't have Autodesk SPDS 2018 Module to uninstall. Any other suggestions? I am running 2019.
Message 34 of 35
yes great this does work!!  I had the same issue on 2018, went into the Control panel, to Installed Programs and removed the Autodesk SPDS module, restarted CAD and now the hatch all has corner grips. thanks for this!!!!!!!!
Message 35 of 35
I have the same problem with this, my hatch didn't have any grip. but after deleted SPDS for autoCAD 2018 it worked again. maybe that's the problem sir
Forma Design Contest
