Help me, please, to get grips of the hatches in Autocad 2018.
I already tried to disassociate many hatches in various way: exploded boundaries; changed settings in Properties and Hatch Editor, and even opened some older dwg files (2011 and 2013 version) which contains disassociated hatches but the results are the same – hatches don’t have any boundary grips, except the only one in the center.
Thanks a lot.
Solved by Alfred.NESWADBA. Go to Solution.
Solved by ruslanvremea. Go to Solution.
do you have a "SPDS Extension" installed (some additional options/functions for Russian standards)?
- alfred -
Hi, I got stuck with the same problem.
Witch extention you unistall and how?
>> What did you uninstall!!!!!???
Look to post 24 in this thread.
- alfred -
I uninstalled Autodesk SPDS 2018 Module (Russian CAD Standard) and works fine!
yes great this does work!! I had the same issue on 2018, went into the Control panel, to Installed Programs and removed the Autodesk SPDS module, restarted CAD and now the hatch all has corner grips. thanks for this!!!!!!!!
I have the same problem with this, my hatch didn't have any grip. but after deleted SPDS for autoCAD 2018 it worked again. maybe that's the problem sir
