AutoCAD Forum
New dwg defaults to template
8 REPLIES 8
Message 1 of 9
joe_kohli
464 Views, 8 Replies
joe_kohli
So, I'm not sure what I changed but every time I open a new tab in Autocad, it automatically opens a drawing template I have on my computer every single time. Where is this pulling the file from and can this be changed back to default?
Is this where I need to be changing information?
8 REPLIES 8
Message 2 of 9
user181
in reply to: joe_kohli
user181
The Default template for QNEW is where is gets the template for starting a new dwg file.
Message 3 of 9
joe_kohli
in reply to: user181
joe_kohli
Ah, ok! Those are looking for .dwt files correct?
This is what mine looks like:
Message 4 of 9
user181
user181
Yes dwt files
Yes dwt files
Message 5 of 9
joe_kohli
joe_kohli
So why would it still be opening a template when the file location says "none"?
Message 6 of 9
user181
user181
I'm not sure why it still uses a template. I just tried it and it opened a template for me too.  If I right click on the plus sign and select new it opens a dialog to choose a dwg file.
Message 7 of 9
user181
user181
I think when you click the plus to add a new dwg it opens the last template used. I just used the NEW command at the command line and selected a different template and then used the plus and it started with that template again.
Message 8 of 9
ed57gmc
ed57gmc
I believe that the first time you create a new dwg with the template set to NONE, it uses acad.dwt, or at least the settings from that file.
Ed
How to post your code.
Ed
Message 9 of 9
joe_kohli
joe_kohli
I just tried this method and you are correct. That is how it works!
AutoCAD Inside the Factory
