New command: "Line style"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi I suggest new command in Autocad: Line style A Line style is a named collection of Line and Pline settings that controls the appearance of line, such as line type, line type scale (Celtscale), and line weight.
You create line styles to specify the format of line quickly, and to ensure that line conforms to industry or project standards.
• When you create line, it uses the settings of the current line style.
• If you change a setting in a line style, all line objects in the drawing that use the style update automatically.
• You can change the properties of individual objects to override the line style.
• All line styles in your drawing are listed in the line Style drop-down.
• Line style drop-down is substituted Line type drop-down list in properties menu.
• Line style is substituted Line type in Layer command.
• Line weight is deleted in Layer command.
• If ISO lines type are selected in line style, the value of line type scale and value of line weight will be the same.
***THE POST HAS BEEN REFORMATTED FOR CLARITY ***
