AutoCAD Forum
Multiple View Ports in Model Space but can't assign unique UCS orientation
4 REPLIES 4
843 Views, 4 Replies
I'm using AutoCAD 2016 in conjunction with Fabrication and I'm having an issue with multiple View Ports. In previous versions, I was able to have multiple view ports in model space and assign a unique UCS orientation for each view port seperately. Each view port's UCS orientation was independent from the other. In 2016 release, if you change the UCS orientation in one view port, it effects the other viewports. Is there a fix for this? Maybe some default setting that can be unchecked or maybe a numeric value that can be changed.
4 REPLIES 4
skintsubby
Hello and welcome to the forums.
Check out the UCSFOLLOW variable.
Also shown in this thread <<HERE>>
Mark
TheCADnoob
Ack.. @skintsubby sorry about double answer. Forum lag is killing me.
change UCSFOLLOW
CADnoob
in reply to: skintsubby
Thanks. Worked like a charm. Changed value from 0 to 1
in reply to: TheCADnoob
AutoCAD Inside the Factory
