Autocad 2015 Printing PDF with streaks through solid colors
Message 1 of 8
I hope all is well. I'm writing on this forum for help with an AutoCAD issue my team is seeing with AutoCAD Architecture 2015.
AutoCAD Architecture 2015 - Product version J.210.0.0, SP 2
Our staff here will print from AutoCAD Architecture 2015 - to PDF - then print the PDF - from a new Canon iR-ADV C3325/3330 printer.
On the PC's monitor the solid colors in the drawing look normal, but once the job is printed, the print will come out with streaks/small lines through some of the solid colors.
If you open the same drawing in Revit 2015 - print to PDF - then send it to the new Canon iR-ADV C3325/3330, the prints come out perfect - with no lines.
Any idea why steaks would come through the AutoCAD PDF and not the Revit PDF when printing? Smiley Indifferent
Vent:
I ususally prefer to speak to a support representative because it is the quickest way to resolve an issue, but Autodesk only likes to return calls promptly if they are dealing with sales. All other calls go to a voicemail. Once its there, they will only call back after business hours when you are no longer in the office. I will specifically request times during business hours and never recieve calls during that time. Might be the worst support I've seen from a major vendor. Smiley Mad
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Can you recreate this with a new drawing, just one hatch with solid pattern and then print to PDF?
If so please upload this drawing + this PDF.
Another question: when you don't print to PDF (I assume you are using the driver "DWG to PDF.pc3", are you?) and then from PDF to printer .... instead printing directly from AutoCAD to the printer, does that work?
And have you tried to print the PDF to any other printer?
What software are you using to print the PDF?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
pendean
Community Legend
Community Legend
show us with visuals/screenshots/pictures when you answer Alfred's excellent questions.
Message 4 of 8
john.vellek
Hi MeganD4313
What are you using to print PDFs from Revit? And, Which driver are you using to print from AutoCAD Architecture? Have you compared the properties of each driver to see where there might be dissimilarities?
Next, are you using the same application to send the PDFs to the printer? Which application are you using?
Which printer driver are you using for the Canon? Are there configuration options available in the driver?
John Vellek
Message 5 of 8
john.vellek
Hi MeganD4313,
I am checking back to see if my post or @ helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 6 of 8
Hello and thanks for responding to my post.
I have reviewed these questions with the staff members. The border of the hatch plains change to a different color creating a pattern. - Attached are screen shots.
What are you using to print PDFs from Revit? - Bluebeam Revu 2016 (Adobe Acrobat will do the same thing)
What driver are you using to print from AutoCAD Architecture? - Canon iR-ADV C3325/3330 PS3 Printer Drivers
Are you using the same application to send the PDFs to the printer - Yes Bluebeam Revu 2016 and Adobe Acrobat as a test - both coming out with the issue. I'm not sure if there are configuration options available in the driver.
Please see images in my drop box account. You can see the lines in the PDF
https://www.dropbox.com/home?preview=example.pdf ( < PDF example )
https://www.dropbox.com/s/90a4o4mimde5cwe/BGarage%20plan_0204%20survey.dwg?dl=0 ( < file example )
I look forward to hearing back from you
-Phil
Message 7 of 8
-Phil
Message 8 of 8
Alfred.NESWADBA
my questions are not answered like:
And questions like that:
Have you tried to use "DWG to PDF.pc3" to create the PDF from AutoCAD
Which program did you use to open the PDF and send the PDF to the printer(s)
At least: your pdf is not downloadable.
Your DWG (without the missing CTB file) looks correct when I print it to PDF using the "DWG to PDF.pc3" driver (please find attachment) ... and that is how it looks on my system viewing the PDF:
Is it different on your screen/printer?
- alfred -
Alfred NESWADBA
