Multileader with tagbox and multiline text
Is there any custom multi leaders with the possibility of having a tagbox and a multiline text that stays as one object? Currently this is three different items and would like to make it as one.
See picture.
pendean
Community Legend
Community Legend
You can create your own block to look/be whatever you want (in your case a multi-line attribute for the mtext portion) and add it as a custom MLEADERSTYLE if you cannot find a stock solution already available in MLEADERSTYLE command https://blogs.autodesk.com/autocad/multileaders-tuesday-tips-frank/
HTH
timothy_crouse
