AutoCAD Forum
Multileader with Field problem
4 REPLIES 4
hencoop
207 Views, 4 Replies
Hello all,
I have a problem with multileaders that contain a field.
The contents are missing when dragging and the frame acts as if there is no content whether the frame is visible or not.  This results in the attachment point flipping when it should not.  See photo - the 2 items highlighted are  dragged up and left (the unhighlighted location).
Any ideas on how to fix this?
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Ver.: 13.6.1781.0 Civil 3D 2024.3 Update
Built On:        U.152.0.0 AutoCAD 2024.1.2
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
4 REPLIES 4
pendean
in reply to: hencoop
Can you share that snippet of the DWG file here? Confirm the issue is still present.
hencoop
in reply to: pendean
The field is from a sheetset.  I'm not sure that the circumstances can be duplicated with only the Multileader objects.  Can you create a couple of Multileaders, one with a field and one without and see if it is a common problem?  Maybe it is related to the sheetset source of the field.  I can check that by using a field from another source.
hencoop
I used an object as the field source... no change.  Converting the field to text eliminated the problem.
hencoop
If you can't reproduce the problem, I'll send you the multileaders (dwg) and the sheetset so you can see if the problem persists on your system.
Forma Design Contest
