Hello all,
I have a problem with multileaders that contain a field.
The contents are missing when dragging and the frame acts as if there is no content whether the frame is visible or not. This results in the attachment point flipping when it should not. See photo - the 2 items highlighted are dragged up and left (the unhighlighted location).
Any ideas on how to fix this?
The field is from a sheetset. I'm not sure that the circumstances can be duplicated with only the Multileader objects. Can you create a couple of Multileaders, one with a field and one without and see if it is a common problem? Maybe it is related to the sheetset source of the field. I can check that by using a field from another source.
I used an object as the field source... no change. Converting the field to text eliminated the problem.
If you can't reproduce the problem, I'll send you the multileaders (dwg) and the sheetset so you can see if the problem persists on your system.
