AutoCAD Forum
Multileader ByBlock even if specified as ByLayer
4 REPLIES 4
A.Hanssens
231 Views, 4 Replies
When creating a multileader style with all settings set to ByLayer, the created multileader still ends up in the wrong color as it is created ByBlock. What am I doing wrong here?
4 REPLIES 4
cadffm
in reply to: A.Hanssens
you cutted out and blacked the mleader style name in dialog and palette 😞
so we can guess you compare 2 different mleader styles.
Or you didn't tested with a newly created mleader and your old one has property overrides.
Easy to answer all by having your .dwg,
but with a edited Screenshot only, we have to guess.
Sie haben den Mleader-Stilnamen im Dialog und in der Palette ausgeschnitten und geschwärzt 😞
Wir können also vermuten, dass Sie zwei verschiedene Mleader-Stile vergleichen.
Oder Sie haben nicht mit einem neu erstellten Mleader getestet und Ihr alter verfügt über Eigenschaftsüberschreibungen.
Mit Ihrer .dwg-Datei lässt sich alles ganz einfach beantworten.
aber nur mit einem bearbeiteten Screenshot müssen wir raten.
Sebastian
cadffm
add:
Last picture, first row:
This is the color of the whole Mleader object, that's nothing you controle within the mleader style.
Note: If you used a newly created mleader for this screenshot, it looks like your current color setting is "ByBlock",
what is really unusual - except you want to work for an our inside your blockdefinition.
[F1] CECOLOR -> ByLayer
Sebastian
A.Hanssens
@cadffm
Changing property CECOLOR from "BYBLOCK" to "BYLAYER" solved my issue.
Multileaders are now correctly created "BYLAYER".
Thanks!
pendean
@A.Hanssens This list and marked settings from HELP in the program may help you in the future
Technology Administrators
