Multi Leader Style won't center Lower case letters
jryan4GYAA
Message 1 of 14
jryan4GYAA
I created a Bill Of Materials and note numbering/lettering Multileader Style that won't center around lower case letters. Block that the style was created from is on the right and Multileader on left. Any idea how to get my lower case "A" to center in my Multi Leader Style? I have attached the (dwg) block used to create.
Replies (13)
Message 2 of 14
cheryl.buck
Autodesk Support
Autodesk Support
Hi @jryan4GYAA,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Thank you for sharing the file. I see that you have used a the block in the multileader. Can you share the steps you used to create it? If you could provide a ScreenCast, that would help.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 14
jryan4GYAA
Cheryl,
Like people used to say on A.M. Talk shows. Longtime listener (or in this case Autocad) First time caller (contributor). Thanks for getting back with me so soon. I have downloaded and learned how to Screencast. I have uploaded it per your request.
Message 4 of 14
cheryl.buck
Autodesk Support
Autodesk Support
Hi @jryan4GYAA,
Thanks! Do you have the link that you can share? I'll be off-line in a few but would be happy to take a look tomorrow.
All the best,
Cheryl Buck
Message 5 of 14
jryan4GYAA
Not sue if the Screencast is visible or not? I just picked insert. Hopefully that helps
Message 6 of 14
Kent1Cooper
Does it make a difference if you use Middle-Center justification for the Attribute, rather than Middle?  [I doubt it, but just in case....]
Kent Cooper, AIA
Message 7 of 14
jryan4GYAA
Ken,
I just tried putting the block back to middle center and it does not effect the Multi-Leader Style. The only way I have found to solve my problem is to create a second MLS that uses a different block which is offset to compensate for the error. I was trying to avoid in the first place. If this was just myself and the other drafters in our company using it that wouldn't be so much a problem. However this is part of a template I am creating for multiple companies to use and I don't have direct communication with any of them to express the work around.
Message 8 of 14
Kent1Cooper
[Are they willing to go with capital letters?]
Kent Cooper, AIA
Message 9 of 14
jryan4GYAA
We are using this for standards documents for a local utility. We use numbers for BOM (Bill of Materials) items, Upper cased letters for Instructions, Roman numerals for Notes and Lower cased letters for References. So I am kinda stuck.
Message 10 of 14
JTBWorld
It will center if you add a letter like b.
What you see seems to be a bug in AutoCAD.
For reference see What is Line Space Style in mtext in CAD?
A workaround would be to make the attdef multiline and manually move it so it looks centered.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 11 of 14
jryan4GYAA
The thing that bugs me the most is that the original block is not a problem its when it is used as a multi-leader Style were it falls apart.multileader discussion.JPG
Message 12 of 14
JTBWorld
I agree. You can let Autodesk know about it here
Jimmy Bergmark
Message 13 of 14
cheryl.buck
Autodesk Support
Autodesk Support
Hi @jryan4GYAA,
I apologize for the long delay in getting back to you. I thought I had posted that I was reaching out on this.
Yes, as @JTBWorld mentioned, it does seem to be specific to only certain letters in specific fonts.  The Product Feedback link would be the best way to report the issue.
In the mean time, you might try using a different font.
To mark a solution that answered the question or resolved the issue, click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Message 14 of 14
jryan4GYAA
Unfortunately This is not an option for us. The client has a specified font that is required and this affects thousands of pages in hundreds of drawings. So for now I will stick to the work around that I came up with which to create a second block and multi-leader style with the text shifted to compensate for the error. Then switch back and forth when needing to adjust.
Thanks for your time on this matter.
