move autocad program
hello,currently i have the autocad 2017 with license on the older laptop, by now i already buy new high spec laptop.can i move from the older laptop to new high spec with license?
and it that is legal or not?
ennujozlagam
hello, yes it is legal it just license transfer. you can refer to this LINK. thanks
jayhar
If it's a licensed copy, you should have the install disk or install file. Just reinstall to the new computer and enter the serial/key when requested. If you no longer have the disk or key, you'll need to contact autocad support.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Many thanks to you,,i try it..
