change default ucs rotation from 180 to 90
AutoMarcus
Message 1 of 11
AutoMarcus
ok so you know the UCS command
I regularly have to rotate x by 90 degrees, once upon i believe this was the default.
now i type ucs > x > then it says 180
so i have to type 90
its a small thing, but what happened to 90 being the default, and how can i change it back?
Replies (10)
Message 2 of 11
-FDC-
Try units, click direction, and set base angle to east.
Message 3 of 11
jayhar
Command: UCS
Current ucs name:  *NO NAME*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>:
Specify point on X-axis or <accept>: direction to x axis at first point
Specify point on the XY plane or <accept>: direction to y axis at second point
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 4 of 11
AutoMarcus
thanks mate, i tried east, and it defaulted to 270, so i chose other 90, if it stops working ill update
Message 5 of 11
AGW-PE
Was looking for a resolution on this as well. It looks like this was resolved 12 months ago, but the listed solution doesn't solve my issue. I am using AutoCAD 2020 and the default UCS rotation angle is set to 180.
Here's the system variable that sets this angle: UCSAXISANG
Steps to fix:
Enter 'setvar' at the command line
Enter the system variable name: 'ucsaxisang'
Enter the preferred value: '90'
That should set the default USC angle to 90.
Message 6 of 11
AutoMarcus
I just had this happen again, thanks
UCSAXISANG
worked
Message 7 of 11
mask1
Community Visitor
Community Visitor
This does not work. Just tried in AutoCAD 2023 and east is always perma set on 0 and will not change to 90. Better answer please
Message 8 of 11
mask1
Community Visitor
Community Visitor
90 is apparently an invalid value for this variable, try again
Message 9 of 11
pendean
Community Legend
Community Legend
Message 10 of 11
AGW-PE
I just modified this setting in AutoCAD 2023. Worked as described above.
Message 11 of 11
jestiron
Observer
Observer
That was the solution I was searching for!  Thank you for this! -Jest
