>> I want use just one layout,but I want more papers inside it
As a layout only has one paperspace a layout is not designed to work that way. The intention is to create a layout for each paper you need (to plot or to save to PDF).
>> more papers inside it, so I can export to PDF quickly
You can run command _PUBLISH to export multiple layouts into a PDF with one command and one button OK.
What you you doing to be more quick?
>> Many layouts make my laptop harmful
Switching between layouts might need it's time, but the performance while working on the model does not slow down when having more layouts ... at least my experience, what exactly is slower on your system when having multiple layouts.
Additionally to this, what are your system specs (cpu, gpu, memory, operating system)?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
