Scaling and exporting Need HELP!
Hi I am just starting to learn autocad as part of my job and I have a question that I cannot seem to find an answer to.
I have my first floor plan than I have drawn in autocad.
The unit type is engineering and insertion scale is in inches.
The grid x and y spacing is set at 0.5".
Now when putting my drawing form autocad into a .pdf file, I need to scale this drawing to  the scale of 1/4" = 1'.
So a quarter inch = a foot.
I know how to export a .dwg to pdf file using the plotting function. I know there is a scale function in autocad and furthermore a scaling option in the export mini browser. But I do not know how to use it to scale to this particular scaling system.
Furthermore, when I use the scaling function, the dimensions that I have plotted on the floor plan do not seem to resemble anything useful after attempting to scale to the setting I need. Is this an unavoidable side effect or can it be helped?
Can I have some help please?
Attached is the drawing I am talking about.
Thank you
Alfred.NESWADBA
Please do not scale your object just to plot, instead create a layout with the papersize you want to have for your PDF, in this layout create one viewport and that viewport has a "standard scale" setting (or "custom scale" for the ones who want to type in the value) which defines the relation between model-size and plot-size. So it does not scale the object itself, it only displays the content zoomed out or in to match the viewport-scale setting.
No problem if you don't scale your object 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
