AutoCAD Forum
Model space view is distorted
11 REPLIES 11
Message 1 of 12
1554 Views, 11 Replies
I am working on a drawing that distorts the view when I zoom in
11 REPLIES 11
Message 2 of 12
Try turning hardware acceleration off, see if it helps. (>instructions<)
Also, try updating video card drivers.
Message 3 of 12
Daniel,
I turned off hardware acceleration and looked for video driver updates. Neither one worked.
Message 4 of 12
In that case, I have several questions:
does this issue occur in all files, or just this one?
If just this one, did this file ever work correctly?
If all files, did the issue just start recently?
Have you installed all available updates for AutoCAD?
System Info? (Windows version, cpu/gpu, RAM)
Are you by chance using 4K resolution? If yes, try going down to 1080.
Are you using greater than 100% display scale? If yes, try going down to 100%
Can you post your file? If it works correctly for others, that will (likely) narrow it down to something specific to your system.
Message 5 of 12
Try the attached file
Message 6 of 12
pendean
Get out of perspective view and see if that gets you back to where you need to be https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
Message 7 of 12
vinodkl
Hi @Anonymous
I assume you are having a problem with the perspective view. Type in the command "PERSPECTIVE" and set it to "0"🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Tags (2)
Message 8 of 12
Not sure if you have tried @vinodkl 's and @pendean 's suggestions yet, I did & here is a screen-shot.
Sorry I didn't think of this, but I am almost exclusively 2D...
Message 9 of 12
in reply to: vinodkl
Fixed, "PERSPECTIVE" set it to "0"...Thank you
Message 10 of 12
DavidLoria
I have the same problem but I'd like to actually use perspective instead of just turning it off.  Can you actually fix it?
Message 11 of 12
pendean
in reply to: DavidLoria
@DavidLoria it can't be "the same problem" if you need it on: so... can you elaborate more on your need and share some screenshots perhaps?
Message 12 of 12
DavidLoria
It happens often in different files even on different machines.  I have two views side by side, 1 plan/2d/wireframe and 1 3D/wireframe/perspective.  eventually at some point Ill move the 3d vciew and everything will become distorted/skewed/stretched.  I try switching back and forth between parallel and perspective but that doesn't help.
I will try to remember to grab a screen shot next time it happens.
Forma Design Contest
AutoCAD Beta
