Okay, background. I uninstalled AutoCAD 2016 per white paper instructions and did a reinstallation of AutoCAD 2016.
Now I get this error. "Missing Shortcut blah blah blah" I go to the folder and the acad.exe is missing, by the looks of it there are a ton of folders and files not here either (See image attached). It looks like AutoCAD 2016 never fully installed. I have cleaned out every area the white paper said and even did a find for autocad 2016 in the registry.
AutoCAD 2014 works just fine. I have done a reinstall, Repair and even a full uninstall again. No idea why it seems it does not install all of the files necessary to run AutoCAD 2016.
I also went extreme and uninstalled every single piece of AutoDesk software and cleaned out the registry for anything that said Autodesk. I installed all of the 10 products I use and everyone works but AutoCAD 2016. I am dumfounded.....
I have attached a .png of the AutoCAD 2016 folders content.
M3 Engineering
