- Mute
- Permalink
- Report
Hi! Recently my computer had to be fixed by formtting its system. After doing so all my file were kept (because I was working on a project) but obviously my the aplications were deleted. Afterwards I installed AutoCAD 2016 (student trial for 3 years) with everyting I needed, AutoCAD 2016 itself and AutoDesk... but, when I tried to apply any materials it told that some file were corupted and had to be fixed. Obviously as you can tell I am not a 100% expert on AutoCAD's "missing files and what to do next" So I googled it and I came up with this (AutoDesk) page which mentioned: How to uninstall and reinstall Autodesk Material Library. I managed to unisntall the files and only install the medium materials library, but not the base material library or the missing libraries I require. And I can't fine any suggestions on how to "manually install" the libraries or use the (InstallationMedia)\Content\ADSKMaterials\2016\ILB\BaseImageLibrary2016.msi, which doesn't appear on that directory (only the "Material Library 2016" but thats it.
So I need help from anyone who knows or might now how to solve the problem, I need the material libraries so I can render, or at least apply the textures I need for my work.
Thanks!
-Sebastian SB
