"Cannot sweep or extrude an object of this type. " - Extrusion Help
Message 1 of 9
I've already scoured the internet for a solution for this problem, but no luck.
The problem is that I get "Cannot sweep or extrude an object of this type. "  when selecting the object to extrude. The shape seems closed (I can hatch it). I tried to use the region function, but I get "1 closed, degenerate or unsupported object rejected." I am relatively new to this so I have attached the file.
Maybe it is the odd shape that doesn't allow extrusion? (holes)
Replies (8)
Message 2 of 9
dbroad
You cannot extrude a block.  Explode it first. Then use mpedit to convert all the lines into separate closed polylines.  Then extrude each one.  If this is supposed to be a panel with holes, then convert the plines into regions and use the subtract command to create a holy region.  Then extrude that.
Alternative technique:  Use boundary to  create all the closed lwpolylines.  Erase the block and continue creating the region and then the extrusion.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 9
Ok, thanks. I am a bit confused with types because everything looks the same ^^
Message 4 of 9
dbroad
Turn on your properties palette (CTRL+1).  When you select the object by picking, the properties and object type(s) will be listed.  If you are a beginner, I highly recommend taking an AutoCAD class that covers the basics.  Look for a college or trade school near you or look for an online course.
Message 5 of 9
This is fine. I only needed to 3D print this object for a custom keyboard project.
Message 6 of 9
JDMather
@Anonymous wrote:
...The problem is that I get "Cannot sweep or extrude an object of this type. "  ...
You might try Presspull command rather than Extrude.
Message 7 of 9
dbroad
@JDMather:  Yes, that would be a better, quicker,simpler solution.
Message 8 of 9
Cool, I'll try that first when I get home 🙂
Message 9 of 9
tk.sruthi
Community Visitor
Community Visitor
@dbroad  Thank you so much for this answer. It solved a similar problem I had.
