hi guys,
I want to install DWG TrueView 2014 but in the installation an error appear that I must install Microsoft.NET Framework 2.0.
I already have this Microsoft.Net Framework 4.0 in my machine. i just need help to solve this issue. Thanks a lot.
Im using Windows 8 64Bit Laptop
Edwin
Framework 4.0 is not the same as framework 2.0
Try this.
Microsoft .NET framework v 2.0 SP2
HTH
DJ
its ok now, what i did is I check DWG TrueView 2015 and its compatible to Framework 4.0, I Installed the TrueView 2015 instead of 2014 Version. so i dont need to install the Framework 2.0.
Thanks drjohn for the reply.
