I did about 11 drawings by inserting Google Earth images into the drawing by using the insert Raster Image Reference but now it doesn't want to work normally.
If i click on the insert it doesn't show the window to go choose the image it shows the dynamic entry option saying path to IMAGE file to attach and I don't know how to fix this and when I went to Save as it did the same I had to input the path instead of being able to go through the folders and selecting the path needed in this manner. I came to the conclusion that it has to be a setting but I have no idea what the setting is any help would be appreciated please.
Hi , Johan57
you can fix that by typing " filedia " in command line and change the value from 0 to 1
Hisham Fawzy
Civil 3d Certified Professional | Civil 3d Instructor
https://www.youtube.com/HishamFawzy
Thanks a lot I'm still learning AutoCAD thanks did it and everythings working now thanks. 😄
