AutoCAD Forum
MENUBAR IN ACAD2019
8 REPLIES 8
Message 1 of 9
RvW000
1566 Views, 8 Replies
MENUBAR IN ACAD2019
What has happened to MENUBAR <1> in ACAD2019
In 2018 switching on <1> MENUBAR brought up an array of drop-down menus:
File  Edit  View  Insert  Format  Tools  Draw  Dimension Modify Parametric  Express Window Help
In 2019 switching on MENUBAR brings up only a repeat of:
Express Tools  Vehicle Tracking
What's that all about!?
I know the MENUBAR is an old relic, but I have worked with it for 30 years....it is a way faster command access than any ribbons, which take an age to open.
Without it I have now idea how to access things like Format/Point Style at the click of a button.
8 REPLIES 8
Message 2 of 9
sthompson1021
in reply to: RvW000
wrong post
Message 3 of 9
RobDraw
in reply to: RvW000
Maybe it's time to start exploring the multiple other ways to access commands so that you are ready for when the menubar is no longer an option.
Rob
Message 4 of 9
tboehler
in reply to: RvW000
This is still there in 2018 - pulldown on the QA tool barThis is still there in 2018 - pulldown on the QA tool bar
Message 5 of 9
imadHabash
in reply to: RvW000
would you please try to reset AutoCAD to default settings and see if any changes .  >> Click <<
Imad Habash
Message 6 of 9
MENUBAR to 1 works at my end as expected.  I would agree with @imadHabash and try the reset to defaults.  I've heard of this issue occuring in some verticals (AutoCAD Architecture is one that I know does it)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Message 7 of 9
RvW000
in reply to: chriscowgill7373
Thanks for the advice.
Unfortunately I have reset back to default.
Rerun MENUBAR  <1> command and MENUBAR  appears with Vehicle Tracking add-on replicated (it is also a ribbon below)
see attached screengrab
Message 8 of 9
chriscowgill7373
in reply to: RvW000
You are running AutoCAD Architecture which is not the same as AutoCAD, there is no menubar unless you manually create one.  ACADA, which is one of the specific examples I provided that does not have a menubar has not had a menubar since 2010.  If you had one in AutoCAD Architecture 2018, it was because someone manually created it, or possibly migrated it from an ancient release.
Message 9 of 9
GrantsPirate
in reply to: RvW000
If by chance you want to run your setup as vanilla AutoCAD and not have all the Architecture add-ons open, then make a shortcut on your desktop and edit the properties for that at the target line.
Mine looks like this
"C:\Program Files\Autodesk\AutoCAD 2018\acad.exe" /product ACAD /language "en-US"
Adjust for your situation.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Forma Design Contest
