AutoCAD Forum
Measuring the creepage distance.
2 REPLIES 2
496 Views, 2 Replies
Hi, I'm new this autoCAD. I was wondering if anyone knows how to measure the creepage distance for a 3D object. The definition of creepage is shown in the picture. However, the design I'm working with is more complicated than the picture since the lines are more ridged. Thanks.
2 REPLIES 2
RobDraw
There are many ways.
The simplest would be to just add up the distances.
You could draw a polyline and get the length from that.
Rob
Kent1Cooper
I would JOIN the parts that make up the creepage "path" into a Polyline, then single-point BREAK it where each vertical hits, and LIST or the Properties palette will tell you how long the result is.
Kent Cooper, AIA
Forma Design Contest
AutoCAD Beta
