AutoCAD Forum
Macro to create LOTS of Layout Tabs.
2 REPLIES 2
spence7
656 Views, 2 Replies
Good day,
       So I set-up a layout just the way I like.  Printer configuration, view-port layer colors and properties, arrangement of v-ps. Real nice.
So I hit the record macro button. Use the pull-up on my first tab to "Move or Copy" in that window i hit "Create a Copy" select "(move to end)" and finally OK. Stop recording. Fill in the blanks in create macro dialogue. and so far so good.
       I hit play and it runs and says " Layout with that name already exists. Macro cancelled"  Shucks.
I would love to be able to insert a layout name but Where? How? When
                        Thank you for looking at my query.            Spence Ball                         Silver Spring, MD           USA
2 REPLIES 2
user181
in reply to: spence7
There is a lisp routine that works well doing that at following link:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-copy-and-auto-number-layout-...
pendean
Q: why not create all the layouts you want ahead of time in a template file, then use that template or drag/drop the layouts from that template when you need them?
Forma Design Contest
