.lsp file will not run in AutoCad2020
Message 1 of 13
Hi All,
So I have a .lsp file that I have been using in AutoCAD 2014 for a few years, and it has been working fine. I have upgraded my computer and my software to 2020 and now the .lsp will load, but will not run. It says error; quit/ abort.
Anyone know how I can try and make it work? The original script was written in 2004.
Replies (12)
Message 2 of 13
ennujozlagam
try to load from appload command and see if helps. thanks
Message 3 of 13
BeKirra
"It says error; quit/ abort."
"The original script was written in 2004. "
Assuming your LSP is in SFSP.
And apart from what  @ennujozlagam replied, one of the possibilities is some system variable(s) used in your LSP have been updated/revised by Autodesk.
Can you upload your LSP file?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 4 of 13
Thanks very much for your suggestion. That is how I was trying to load it. That and in the 'User Interface'.
Message 5 of 13
Hi. Thanks for your response. I will upload the file below. Thanks
Message 6 of 13
ennujozlagam
i managed to load but need to check if it is woking? what are the lsp command you commonly used. thanks
Message 7 of 13
Hi, Thanks. Yes that is as far as I get. I then use CSNDGS command to run it, but that is where it comes unstuck. It should open a dialogue box.
Message 8 of 13
ennujozlagam
you can try this, please see screencast video and see if helps. thanks
Message 9 of 13
ennujozlagam
i tried again. sorry it's not working my apology. ignore my screencast video above. thanks
Message 10 of 13
BeKirra
I am afraid your dialog file "c_sndgs.dcl" is missing.
X² + Y² = C²
Message 11 of 13
vinodkl
Try linking the DCL file which seems to be missing with the lisp.
Check this: click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 12 of 13
Thankyou!!! I had to move both files into C:\Program Files\Autodesk\AutoCAD 2020\Support to make it work, it wouldn't work from anywhere else. Thanks very much!
Message 13 of 13
scot-65
Please move your "custom files" away from the default AutoCAD directory.
Create a directory for your utilities and provide a support path (SFSP)
to the directory. Command OPTIONS --> Files tab --> Support File Search Path.
Also declare a Trusted Locations path to this same directory.
Now you are able to migrate/transfer/archive much easier...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
