AUTOCAD 2020 window within program stuck?
jduframe
Message 1 of 10
jduframe
AutoCAD was working fine working on current drawing then went to file explorer, double clicked a second drawing to open within Auto cad and the window inside auto cad program tiled , but now does not let me expand this window I have even exited both drawings and closed AutoCad, reopened AutoCad and it still comes up like shown in pictures below and I can click the maximize/minimize button and it does nothing. Why is this stuck like this now?
Replies (9)
Message 2 of 10
jduframe
I am going to restart my PC and see if this helps
Message 3 of 10
jduframe
rebooting computer didn't help
Message 4 of 10
jduframe
Reopening drawing tried maximizing, closed drawing, reopened, did this few times, I think on the 4th or 5th try it finally expanded the window correctly. Must have been some sort of glitch in AutoCAD.AUTOCAD2.JPG
Message 5 of 10
aagalan
Try this, It works for me
Message 6 of 10
Alfred.NESWADBA
If so then please make sure your AutoCAD is updated, command _ABOUT should show that:
But I guess it's more an issue of the graphic card or the installed driver.
Am I correct that command _ABOUT shows Intel HD as GPU device? Can you show us a screenshot from that dialog?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 10
jduframe
Mine is not updated, as shown below, I will do that now
Message 8 of 10
jduframe
Cant get the update to work
message I receive after download and click to install
Message 9 of 10
cadffm
2020.1.1 is the problem!
Or better Autodesk programmers are.
You can not install 2020.1.2 on a 2020.1.1
Try to DEinstall 2020.1.1 update (i couldn't deinstall 2020.1.1, can You deinstall it?)
Sebastian
Message 10 of 10
jduframe
that worked thanks, now I have AutoCad Updated
