Lineweight in model not as in layer settings
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello!
I want to draw inside the model space and print from the model space.
I want the lines/polylines to be displayed as set in the layer settings or any other settings. "See as set".
Now I made different layers for my polylines with different colors and linestrengths.
If I create a polyline on the according layer, it does not change its strength. The color is correct. Only the strength is not correct. In the layer settings I set the strength to 1mm. The model space shows a 0mm thin line. If I set it manually inside the properties window, it shows the correct thickness.
LWDISPLAY is not doing the job, because for some reason it increases the linestrength to 1mm (it just slightly gets bigger) and it rounds the ends of the line which is definitely not what I want.
How can I make the linestrength visible as set in the layer properties?
