AutoCAD Forum
Linetype
2 REPLIES 2
232 Views, 2 Replies
Linetype
I have my linetypes that doesn't display correctly with 2d polyline when fitted (see file below).
Can someone knows why and knows the solution?
Thank you!
Olivier Cassette
2 REPLIES 2
Alfred.NESWADBA
Not sure if I know what you see as "not correct".
But for polylines and linetypes ... select the polyline, in the property window change it's "Linetype generation" to "enabled", is that ok for you then?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Yes, it works! So simple... Thank you very much! 🙂
Olivier
Forma Design Contest
AutoCAD Beta
