326 Vistas, 2 Respuestas
Linetype
I have my linetypes that doesn't display correctly with 2d polyline when fitted (see file below).
Can someone knows why and knows the solution?
Thank you!
Olivier Cassette
Alfred.NESWADBA
en respuesta a: Anonymous
Not sure if I know what you see as "not correct".
But for polylines and linetypes ... select the polyline, in the property window change it's "Linetype generation" to "enabled", is that ok for you then?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Yes, it works! So simple... Thank you very much! :cara_con_una_leve_sonrisa:
Olivier
