Linestyle double lines parallel - AutoCAD
srleone
srleone
I also need a double line linetype that I can share within a .lin file. I want to draw a single line, but have it appear as two parallel lines.
@srleone This post has been moved to a new thread for this question and the title modified - CGBenner
RSomppi
Kent1Cooper
@srleone wrote:
.... a double line linetype that I can share within a .lin file. ... draw a single line, but have it appear as two parallel lines.
The only way I can think of to do that is with a linetype involving a Shape or a Text character.  Here's an = sign in the TXT.shx font (above), and a series of them, slightly overlapping (below), that could be accomplished in a linetype definition:
But curves would be kinky:
And things like changes in direction in Polylines would not look as I expect you would want them to:
A Multiline Style would overcome the latter, but [as pointed out already] curves would be out of the question, unless drawn kinky in segments [but the segment joints would at least be cleaner than the above].
Kent Cooper, AIA
CGBenner
@srleone
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
