I'm trying to figure out how to make it so lines(dimension, center-lines, continuous, etc.) don't interfere with my center marks on my circles. Can anyone explain how to do this? Below I've provided a pictures.
Thanks!
Solved by Alfred.NESWADBA. Go to Solution.
welcome @Anonymous.autodesk.com!
For dimension lines you can edit your dimension-style and modify the "Offset from origin" parameter there:
For the center-lines it depends if you are using AutoCAD 2017 and the center-line objects or if you are doing that with standard lines.
With standard lines there is no option to have a spacing set to make this automatically.
- alfred -
Thank you Alfred. So for any other lines other than dimension lines I can't have an automatic offset from my center-marks unless I'm using Autocad 2017?
When drawing your center lines start them at the Quadrant of the circles not the center of the circles
When dimensioning use the quadrant of the circle not the Center
To be more clear: AutoCAD 2017 also can't do that with normal lines, so lines that have a dashed or dashed-dot linetype do not recognize if they are intersecting any other objects.
The difference in AutoCAD 2017, which helps in that specific case, is the new object "center-line" which knows how to act in the center of circles, and set parameters to the spacings from center, ...
If you really need that in older AutoCAD releases the chances are:
But both are workaround with very little quality.
- alfred -
