>> So for any other lines other than dimension lines I can't have an automatic offset
>> from my center-marks unless I'm using Autocad 2017?
To be more clear: AutoCAD 2017 also can't do that with normal lines, so lines that have a dashed or dashed-dot linetype do not recognize if they are intersecting any other objects.
The difference in AutoCAD 2017, which helps in that specific case, is the new object "center-line" which knows how to act in the center of circles, and set parameters to the spacings from center, ...
If you really need that in older AutoCAD releases the chances are:
- create a block with a wipeout + a center-line-mark and position that block in the center of the circle
- use multiple center-lines ending before and starting after the center of the circle.
But both are workaround with very little quality.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
