AutoCAD Forum
Lines are plotted inaccurately at odd angles.
11 REPLIES 11
Message 1 of 12
873 Views, 11 Replies
Lines that  appear to connect and be parallel in model space are not parallel or connect in the plot.
I have attached some screenshots of the lines in model space and after being plotted.
Labels (3)
11 REPLIES 11
Message 2 of 12
qnologi
Message 3 of 12
in reply to: qnologi
Thanks for your reply,
I've looked at the link you sent and have made some changes, including plotting from paper space (as I had been plotting straight from model space). This has seemed to fix  some of the lines but others still aren't quite right.
I've attached another image showing what the plotted view looks like now.
Message 4 of 12
pendean
Can you share an actual DWG file and a PDF printout that shows the issue clearly.
And confirm your 2019 is current, ABOUT command should list it as 2019.1.2.
Message 5 of 12
in reply to: pendean
Version is up to date as 2019.1.2.
If you look in the attached files, the problem occurs around the window frames.
Message 6 of 12
imadHabash
Honestly ... i don't see any error in your pdf file except that your frame is not printed . you can check my attached pdf file and see if any changes .
Imad Habash
Message 7 of 12
pendean
Wait, Wait Wait, this drawing is totally messed up, are you not drafting at 1:1 scale? In your inches-units floor plan, your doors are an inch and a half wide. Are you really drawing to a printed page scale?
Does your teacher not teach drafting at 1:1 scale in AutoCAD?
So... back to the issue, on an 8.5x11 PDF you are worried a window less than a foot wide wide on a floor plan scaled in a viewport at 2:1 scale is misaligned? I suspect all you see are the few pixels trying to pretend they are wider.
Go talk to your teacher please, you need some basic drafting help at 1:1 scale.
Message 8 of 12
I was drawing at 1:1, I just copied the piece I was having issues with into a new DWG file.
Message 9 of 12
pendean
What units of measurement are you drawing?
Your drawing is not 1:1 if this is not for a model that fits on your lap, did you not think it was weird you have to print your floor plan on a letter sheet of paper at 2x scale?
Message 10 of 12
I've fixed the scaling of the drawing, the units were in mm, when I  thought they were in m. However the lines are still being plotted at odd angles. Lines that are parallel when looking at their properties are not parallel when they've been plotted to a pdf.
Message 11 of 12
vinodkl
At 6400% zoom, it is expected to see objects like that which are at odd angles in PDF🙂
No matter how you plot even at the highest quality that's how it's going to be in the PDF when you zoom in so deep.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 12 of 12
pendean
Post your fixed DWG file please: note that if you are still trying to create a letter sized sheet PDF of your large building you need to understand there are not enough pixels on the planet to make those tiny windows look parallel. You are seeking the impossible.
I also recommend you and your teacher work on this problem together: I think a more hands-on instruction from them might be the most helpful for your needs.
TIA
AutoCAD Inside the Factory
