Changing multiple Polyline start/end segment widths
ab1426TDE89
ab1426TDE89
Hi, I need to draw lots of polylines all with a set start and end segment width; like shown here at the bottom of this page: https://billboyheritagesurvey.wordpress.com/2014/03/13/the-slippery-slope-cad-hachures/
I know I can do this individually when I draw the line, but I was hoping there was a way of changing the start-end widths after they have all been drawn. That way I can quickly draw it all out and test different start/end thicknesses.
I have tried using the Match Properties tool and the PEDIT tool to no avail. Can anyone help?
I am using AutoCAD 2018 if that helps.
vinodkl
See if this helps:https://www.cadtutor.net/forum/topic/30215-easy-tadpoles/
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
i suggest for you to make and design a custom linetype , try to use this great CAD option . >> Click <<  >> Click1 <<
Imad Habash
ab1426TDE89
Hi! That seems to work really well, apart from they draw at 90° from where I draw the first and second point! Is there any way of changing the code to make it draw in the this? I dont really know anything about lsp.
vinodkl
Post your question about it in lisp & customization forum and they will be able to walk you through🙂
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
ab1426TDE89
Thanks, I'll ask there! Other than that small issue your solution works very well, thanks!
