Line types not showing
CLG1972
Message 1 of 11
CLG1972
I have attached two PDF's with the same section of road. The Pavement Marking Plan has the line types as they should be. The Lot plan has the lines copied from the Pavement Marking Plan, and the ltscale is the same. Both PDF's are in model space, however we are continuously experiencing this problem of the line types not showing up in the XREF, however they appear correct in the drawing that contain the XREF.
Is there something we can do to fix this permanently?
Replies (10)
Message 2 of 11
Kent1Cooper
Look into not just the LTSCALE system variable, but also MSLTSCALE and PSLTSCALE.
Kent Cooper, AIA
Message 3 of 11
CLG1972
Both the MSLTSCALE and PSLTSCALE are the same in both drawings.
Message 4 of 11
Kent1Cooper
To quote from Help about it, "Different layout tabs can have different settings for PSLTSCALE," so .if Paper Space Viewports are involved, check that in all of them.
Kent Cooper, AIA
Message 5 of 11
CLG1972
 The reason I posted was because they do not look the same in model space and I have checked all the PSLTSCALES.
Message 6 of 11
pendean
Community Legend
Community Legend
greetings @CLG1972
Your PDFs do show the problem, but not the cause of it: share source DWG files if you need help finding the cause of the problems.
Message 7 of 11
CLG1972
Please find attached the dwg files.
Message 8 of 11
pendean
Community Legend
Community Legend
@CLG1972
Thanks for the files: but where did
119059-2D-PAVEMENT MARKING PLAN.PDF
come from?
and how did you get
117043-XREF-LOT PLAN.PDF
in the DWG file you posted?
Your DWG file seems to offer no PLOT presets and everything is at a rotates UCS. If I have to create those, then we're not helping you out much with your pre-existing issue.
FYI:
Items Purged | Purge Status
Registry Applications..... | Purged : 20672 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Message 9 of 11
CLG1972
I just want the lines from the Lot Plan to show up the same as the Pavement Marking Plan. It does not involve plotting or UCS rotations. I can not get them to look the same regardless of if the UCS is rotated or not. It obviously does not plot the same way either as per the PDF's attached. This is not the only project where this is a problem.
Message 10 of 11
pendean
Community Legend
Community Legend
@CLG1972 wrote:
I just want the lines from the Lot Plan to show up the same as the Pavement Marking Plan....
That means nothing to me since you provided no details about either. Sorry. This is not the M3D or C3D forum.
@CLG1972 wrote:
...It obviously does not plot the same way either as per the PDF's attached...
From what I gleaned from your one file, this conflict was the major problem, not much else
In our office, we go out of our way to avoid ever setting anything ..._XREF for annotative scale.
If you want to share one or more DWG files to others to test, we can look at those too. If this is a challenge you face system wide, Here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
HTH
Message 11 of 11
Valentin_CAD
@CLG1972 ,
Compare the Custom Scale:
Notice the difference:
These links may provide additional help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
