Bug with editing linear dimensions
ramiz_sadygov
Message 1 of 9
ramiz_sadygov
Hello, I have a certain problem. When editing linear dimensions, the linear dimension text wraps very far from its location. I am attaching a link to YouTube, which shows the problem more clearly.Has anyone had such a problem? Can you help me decide?
AutoCAD version 2023.1
Windows 11 x64
https://youtu.be/UTR_hUnicO4
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Turn off UCSFOLLOW variable, see if your issue goes away.
Message 3 of 9
ramiz_sadygov
I checked the value, it's "0".
Message 4 of 9
pendean
Community Legend
Community Legend
Are both UCS and PLAN commands set to WORLD?
Message 5 of 9
ramiz_sadygov
Yes
Message 6 of 9
Kent1Cooper
If you go ahead and edit the content and OK that, does it end up back where it should be?
Kent Cooper, AIA
Message 7 of 9
Valentin_CAD
@ramiz_sadygov ,
See if its an issue due to "high coordinates".
Try the following suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 8 of 9
ramiz_sadygov
No, it takes me far from the editable size.
Message 9 of 9
ramiz_sadygov
It seems that the problem really was in the coordinates of the dimension line. I shifted all the objects so that they all have positive coordinates on the X and Y axis. And the problem seems to be gone.
Thank you!!
