Hello folks,
Say I completed a 3D object to it's final, and this object is a car part or something else, and for a left side. In AutoCAD, can this object be copied and create an 'inverse' or 'mirror' for a right side use? Hope my English here is clear enough. If possible, what would that (the function) be called in AutoCAD 3D?
Cheers
Solved by Valentin-WSP. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
Oh really. That would be great. I will create a rough 3D model with a non-symetircal shape and try it out.
Thanks for the information.
@omorah ,
Just make sure to use the correct Mirror.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
