AutoCAD Forum
layout viewport
6 REPLIES 6
1938 Views, 6 Replies
layout viewport
in layout viewport there is an option to create an object viewport. how can i create it? i was able to create rectangular or poligonal but not the object viewport.
also, once created, is it possible to move that viewport on paper? i click on the broder of viewport and i am able to manipulate the border of the viewport as i want but i can not just move the whole viewport
6 REPLIES 6
jayhar
<<<<<in layout viewport there is an option to create an object viewport. how can i create it? i was able to create rectangular or poligonal but not the object viewport.>>>>>
Yes, you can create an object viewport, rectangular or poligonal. see the options in Mview.
Command MV enter
MVIEW
Specify corner of viewport or [ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/LAyer/2/3/4] <Fit>:
<<<<<also, once created, is it possible to move that viewport on paper?>>>>>
Yes.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
vladimir_michl
The Object option allows to create and clip a new viewport from an existing closed geometry - e.g. from a polyline.
As for manipulations - in paperspace (see the toggle in AutoCAD status bar), you move the whole viewport relatively to the paper sheet, while in modelspace (click inside the VP) you move the contents of the viewport.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
in reply to: vladimir_michl
yes i understand what object option is for but how do you do it? i select object option and then it tells me to select object but i can not select any object. i am in layout view.
and as for moving the viewports i didnt understand how to move still exactly
jayhar
<<<<yes i understand what object option is for but how do you do it? i select object option and then it tells me to select object but i can not select any object. i am in layout view.
 and as for moving the viewports i didnt understand how to move still exactly>>>>>>
Let Check which viewport are selected & check how many viewports in Layout
in layout, Commands> QSELECT> Object type> select viewport> Operator> Select all> ok
just check how many Viweports
 Can you please upload Autocad 2013 format ????
vladimir_michl
Get familiar with the modelspace and paperspace concept. The source object for the layout view must be drawn in paperspace. And moving the existing viewport should also happen in paperspace (PS vs. MS - see the toggle in the status bar).
neaton
See the attached screencast on creating viewports from objects. I created a circle and polyline object in paperspace then created the viewports using MV command. Notice the polyline needs to be a closed polyline which you can do from Properties or use the Close option when creating the polyline.
Nancy
Forma Design Contest
